Flashman wrote:
Mike134 wrote:
fj12ryder wrote:
If you have more contact surface, you'll have more friction/braking. That's why race cars have very wide tires: bigger tires=better grip.
Yep!! I can tell you paid attention in your HS physics class.
Consider a train - very small contact surface and pulling more than any RV. It is psi on the contact patch - the larger the patch the less PSI if the weight is the same.
Now if that were true, race cars and dragsters would have very skinny tires. But they don't, why do you suppose that is?
