blofgren
Nov 20, 2019Explorer
jerem0621 wrote:tiresLearjet wrote:IdaD wrote:
This one is easy. DRW if you need the carrying capacity because you need it. If you don't, SRW because they're better in every other way.
Except! if a tire blows out towing a trailer...SRW not better :)
If it’s a front tire you are still jacked up
Towing a large fiver, the chances of a rear blow out are MUCH higher than a front.
Another pro for the dually is that you can run a much lower pressure in the rear tires even when towing heavy which contributes to a much better ride. And I love how cool the tires stay.
44,066 PostsLatest Activity: Apr 16, 2026
