trackmagic
Dec 19, 2021Explorer
S&S 8.5 Camper on Ram 2500: Measured weights; advice.
Hello everyone!
I have a 2021 Ram 2500 Cummins short box and a S&S 8.5 camper.
Camper states Dry Weight of 2200. I have it loaded and have taken 6 trips in it and with airbags on truck it drives and handles completely fine.
Took to scales today: No water in tanks, no dogs/passenger in truck, not fully loaded with gear. Relatively empty.
With camper:
Steer Axle: 4980
Drive Axle: 5760
Gross: 10740
Post Camper:
Steer: 4900
Drive: 3100
Gross: 8000
So total camper weight before water/gear, but with battery, two propane, most everything that stays in camper between uses = 2740lbs
I still need to go re-weigh with camper dropped, but think it is at least 1k heavier than the "dry weight of 2.2k" even without water/gear, etc.
Truck specs from door sticker: GVWR 10,000. Front 6k Rear 6,040.
I have the nicer 18k wheels and nice well rated tires, so they aren't the limiting factor.
Loaded with gear I think I will be closer to 11k.
I am interested in peoples thoughts. The truck drives and handles just fine, so not concerned about that. Just got back from ski trip on lots of twisty roads and the body roll is minimal. Braking seems just fine especially combined with diesel exhaust break.
It appears I am below axle weights, but over on gross.
I got a killer deal on truck (was just using for towing at that point) and then practically got this pristine camper given to me. I could not afford a newer/lighter weight 20k+ camper right now. I see my options as either keeping going for awhile with this setup. Trying to sell my current truck and buying an older 1-ton.
Thanks everyone.
With camper:
Steer Axle: 4980
Drive Axle: 5760
Gross: 10740
Post Camper:
Steer: 4900
Drive: 3100
Gross: 8000
Thanks everyone.
