chr$ wrote:
1. LT tires usually have better tread and will resist punctures and heat better IF they are rated for the load you need to carry. Sadly, the only 14" LT tires out there are General Grabbers (LT8.5/70.14) but only had a 1,520 lb weight rating. The ST's that are closest in size are 1,870 lbs. I couldn't even go to 15's because my axles are too close together. Wheel well was no problem. Something to think about if you are considering a larger rim and don't have one of the newer spread axle trailers.
Maxxis UE168n bravo series has 14 inch LT's .. I had the 205R14C
on my previous TH rated at 2270 lbs each. ( 109/107Q service rating )
