- prichardsonExplorerParaffin works well. Take an old candle and rub it along the screw part.
- dee74ExplorerAnyone use graphite spray?
- dclark1946ExplorerRegular WD 40 a couple times a year. No issues with dirt attraction.
Dick - 69_AvionExplorer
pfidahospud wrote:
Silicone spray. Doesn't attract dust. Seems to last well.
That is exactly what I use. You don't want anything that can attract dirt. - Bigbird65ExplorerWhen we first got our trailer I made the mistake of using wheel bearing grease on the lead screws of the manual stabilizer jacks. They turned so easily that under pressure they would unwind or turn back several turns when the pressure was relieved. The fix was to remove the grease with solvent and spray on a lite coat of WD40 to prevent any chance of rusting.
- coolbreeze01ExplorerWD-40® SPECIALIST® WATER RESISTANT SILICONE LUBRICANT
- Winged_OneExplorerDry lube.
- Community AlumniNot applicableAnother vote for motorcycle chain wax. It's dry, stays where you put it, and it repels everything.
- Doug33ExplorerUse WD40 a few times a year, and it doesn't seem to attract dirt and dust that much.
- pfidahospudExplorerSilicone spray. Doesn't attract dust. Seems to last well.
44,071 PostsLatest Activity: Sep 18, 2026
