evanrem's avatar
evanrem
Explorer II
Jun 24, 2015
Stabilizer jack nut missing
The end cap nut that you use to crank down the stab jacks is mia. Anyone know where you can get them. A buddy stopped by the rv dealer and they mentioned you have to buy a new jack. It's squared of on the end where the nut goes on and looks like maybe a pin holds it in place
    Two of my jacks were mangled, so I cut the ends off and welded on 3/4"nuts. Mine are Balco jacks.
  • Beachums wrote:
    Find a 12 point socket that fits the square.
    Probably a better fit with an 8 point socket on a square.
    If the end of the shaft has a hole to accommodate a pin, you could buy the correct sized nut and drill the pin hole in the nut.
  • At the end of the threaded rod is a squared off end which the nut slips onto.
  • Could take the jack off and take it to a welding shop and have them weld a nut of the right size on it, but this could cost as much as a new jack.
  • Might be a replace the whole unit...keep the parts though. Repost when your problem is solved so if I have that problem.
