Hornnumb2ExplorerDec 06, 2017Stabilizers lubeI have been using a dry lube but the threaded rods always have rust on them. Is there something better to use on them, I am in Texas so high humidity. Thanks Michael
amxpressExplorerDec 06, 2017I've always used a product designed for slide gears from Protect All called Slide Out Dry Lube. It works great on my stabilizer worm gears and my slide rack& pinion gears.https://www.amazon.com/Slide-Out-Dry-Lube-Protectant-Protect/dp/B001FCB1JG/ref=sr_1_4?ie=UTF8&qid=1512606548&sr=8-4&keywords=rv+slide+lubricant
Related ContentLube for stabilizer jacksStability controlWhat do you use to lube your stabilizer jacks?Jack LubeToilet seal lube?
