Hornnumb2ExplorerDec 06, 2017Stabilizers lubeI have been using a dry lube but the threaded rods always have rust on them. Is there something better to use on them, I am in Texas so high humidity. Thanks Michael
nineoaks2004ExplorerDec 07, 2017I use a spray designed for garage doors, has worked for me for several years, it is a dry lube and hold up well here in the Fl. climate.
Related ContentLube for stabilizer jacksStability controlWhat do you use to lube your stabilizer jacks?Jack LubeToilet seal lube?
