I have been using a dry lube but the threaded rods always have rust on them. Is there something better to use on them, I am in Texas so high humidity. Thanks Michael
motorcycle chain lubes can work well. Many of them go on like a liquid and then set up as a stiff, dry grease which is almost impervious to washing off. Just be aware, they can work too good. I have two of mine that will not stay in place. The weight of the trailer actually pushes the screw and they unwind. I had to make keepers to hold then in place.
