Reddog1 wrote:
It is unfortunate, but it all probability the majority of the posts on this thread will be negative made by members who have never had a Stable Lift. Never having had a lift sure would bring up a lot of reasonable questions. Never having had a lift really does not put much validity in conclusions.
I have had a lift since 2005, and had to remove it last year due to changing to a DRW truck. I may offer some experiences with my lift later today, depending on how the thread goes.
Wayne
I read the OP's post carefully. The OP was concerned with the 'wobbly jacks" on uneven ground. I don't see how a Stable Lift would help with that, especially if the ground is uneven or sloped. Maybe I'm missing something. I can see them used on a flat surface but not in the woods or ground thats uneven.
Why I said to lower the unit as far as possible on the jacks and make sure the jack to camper mounts ate tight. You never want to use a TC with the jacks extended unless you like being seasick from the sway...
I'm not negative or positive, I just don't understand the OP's post, which is why I commented confused.
