Reddog1 wrote:
notsobigjoe, any particular reason for mounting the single jack on the passenger side? Does the two jack side cause problems with the fuel filler?
Wayne
Mont peters said I should have the two jacks under the heavy side. The fridge is in the slide as well as the batteries are all on that side. Most would have installed it the correct way but he said I and a couple of others were the exception. It was a little tricky in the beginning being on the wrong side and all. Over time it became normal. I have no problems with it anymore.
