hedge wrote:
A couple questions.
1. can you control the individual jack motors individually?
2. why 2 motors on 1 side and 1 on the other? I guess I like congruency
1 You can control each motor individually. There are three toggle switches.
2 Only three motors are required. I see a couple of reasons.
a Depending on which motor the are using, typically it will handle over 3000 lbs. One motor easily lifts one side of the TC and it saves the expense of the second motor.
b With one jack (motor) on one side the TC balances on that jack. The two jacks on the opposite side of the TC tilts (levels) the TC front to rear. All three jacks raise or lower the TC. You can raise or lower the single jack to level side to side or you can raise or lower both of the two jacks to level side to side.
c With one jack, on the driverside it can make it easier to access the fuel filler.
Wayne
