jornvango wrote:
We are considering having a stable-lift system installed on our 2014 Livin Lite 8.6 truck camper.
My lift is mounted on my 11.5 foot 4000 lb Bigfoot TC. You would probably be using the same lift, which means it due to weight and size the lift would not work as hard with your TC.
jornvango wrote:
Since we love to boondock on public lands, we are looking for a solution that will allow us to easily remove the truck camper while we are camping on uneven/unstable ground.
I seldom unload my TC when camping, but when I have I have never found uneven or unstable ground an issue. The lower hoop bridges the low spots, and on real low spots directly under a jack I have put leveling blocks. I have put leveling blocks under the hoop where the tires run over the hoop. It is certainly possible to find ground just too uneven to unload on, but you definitely do not need a graded level surface.
When you say unstable ground, I understand that to mean soft like sand, soft dirt, or mud. The truck I used with my lift is 2WD, so I seldom I avoided serious sand, soft dirt, and mud. I did experiment one time in sand, but not super soft. I put one leveling pad under each of the three jacks and under the hoop where the tire drove over. There was no issue at all. I am sure you could find something too soft but all you will get from a four jack system is four leveling pads.
jornvango wrote:
The 4 wobbly jacks on our TC are too scary for us to use in these circumstances, but we do love to have the truck available for exploring while boondocking. We are currently considering trading in the TC for a travel trailer for this very reason.
I also have a lifted 19.5 foot Alpenlite 5th wheel. My Bigfoot TC with the Stable Lift will go more places and park in more places than the Alpenlite. There are more creature comforts in the Alpenlite.
Loading your TC with the Stable Lift when there are strong wind gust really makes the lift worthwhile. I was loading my TC in the wind with the front jack extensions and had to stop until the next day. That was the final motivator for me, I ordered my lift. With the lift I care less if the wind is blowing.
jornvango wrote:
Obviously, installing a stable-lift will be cheaper than the money we would lose on trading in the TC and buying a travel trailer.
That I can't comment on. I would suggest if you could swing it to have Stable Lift do the install or ask them if they could recommend someone. It is more time consuming than difficult. The most critical is the preload with the tie down feature.
jornvango wrote:
Does anyone have the Stable-lift system and if yes, how is the performance on uneven ground?
I discussed that earlier.
jornvango wrote:
How about taking it off on forest land, desert ... does it sink in case of heavy rains?
My four jack systems have sank in the ground, but my lift never has. Four jack systems or Stable Lift, you can put pads under the jacks or jacks/hoop.
jornvango wrote:
Regarding potential negatives of the product: I'm aware of the difficulty to install (while reading up on the product); I would find a shop to install them.
As I previously stated, it is more time consuming than difficult. I installed mine with no help in two days. You have to remove some appliances to drill holes and install bolts. Each TC is different. I think I can post some photos if I still have them and you are interested.
jornvango wrote:
I'm also aware of the reduced ground clearance.
If installed correctly, it will reduce the ground clearence about 2-1/2" to 3".
A plus I have never seen discussed is the protection the lift give the truck. It important to know the lift is made of heavy wall tubing, 1/8" or thicker. I have got too close to boulders, hitting them with the hoop. I raised the side of the truck and skinned the paint with no damage. Car doors and shopping carts no longer crash into the side of my truck.
Wayne
