Not sure about where you live, but in California, it is illegal to up the price after a quote is given. This is through the BAR, Bureau of Automotive Repair.
If they want to over charge you after the fact, then they can refund your money on the material.
I would take my refund and run from that crooked place. Over $700 to drill 4 holes?! That is a crime! I drilled my RAM leafs out by hand using a batter operated drill without problem. They provided 4 drill bits for the 4 holes and I only needed one to do all 4 holes.
Here's a tip when drilling; I used a horseshoe magnet around the hole I was drilling. Almost all the shavings stuck to the magnet instead of falling down on top of me. The shavings can be hot, so wear full protection. I used a clear full face shield I wear when using my grinder and buttoned my shirt up to the collar.
