mnih wrote:
Ski Pro 3 wrote:
Not sure about where you live, but in California, it is illegal to up the price after a quote is given. This is through the BAR, Bureau of Automotive Repair.
If they want to over charge you after the fact, then they can refund your money on the material.
I would take my refund and run from that crooked place. Over $700 to drill 4 holes?! That is a crime! I drilled my RAM leafs out by hand using a batter operated drill without problem. They provided 4 drill bits for the 4 holes and I only needed one to do all 4 holes.
Here's a tip when drilling; I used a horseshoe magnet around the hole I was drilling. Almost all the shavings stuck to the magnet instead of falling down on top of me. The shavings can be hot, so wear full protection. I used a clear full face shield I wear when using my grinder and buttoned my shirt up to the collar.
Many thanks. Interesting, that California law. I’m in Arizona, anyone know if there’s a law against upping the price? A quick google search turned up nothing useful but I’ll keep looking.
I have a correction;
In my case I had a motorcycle that needed repairs. I took it in to a repair shop and got a quote. When they tore into the motor, they discovered more damage than originally thought. They wanted more money. THAT was legal I think. However, I have the right to turn down the work and cancel any agreement on the quote. And they have to restore the vehicle back to the condition it was in when I dropped it off. In this case, the motorcycle was running, I drove it in. The damage was so bad, in this case the cam shaft was nearly worn in two, that the engine could not be reassembled and made to run. Heck, just gaskets and labor alone would really cost the shop and not me at all. In the end, they honored that quoted price and while I'm sure they didn't loose money, they didn't make as much profit as they might have.
The reason quotes for repair are so high is for hidden damage that would disallow them to return the vehicle back to the condition it was in when it arrived; running.
Hope this makes sense....
In your situation, I would guess you have the right to turn down all the work, including a refund of parts they bought to perform the job if they changed the amount after the fact due to their own miscalculation of how much labor would be involved.
