Beverley_Ken
Jul 16, 2019Explorer
I would definitely pass on that one. If you can see some mould, that maybe all,it may just be the tip. The finished ceiling material is usually laminated to thin Luan (plywood) and that is against the white block foam insulation. The water moisture could have gravitated several feet away from what you can see. I'm not saying that it has, but check the ceiling for soft spots or discolouration. That could lead a big repair. Run
Ken
Ken
44,066 PostsLatest Activity: Apr 15, 2026
