otterslide
Jul 16, 2019Explorer
Beverley&Ken wrote:
I would definitely pass on that one. If you can see some mould, that maybe all,it may just be the tip. The finished ceiling material is usually laminated to thin Luan (plywood) and that is against the white block foam insulation. The water moisture could have gravitated several feet away from what you can see. I'm not saying that it has, but check the ceiling for soft spots or discolouration. That could lead a big repair. Run
Ken
Thanks. I'm new to trailer construction so I didn't know what to look for. Thin wood on top of cheap foam will not resist mold well at all.. and it looks like quite a lot of water came down through there because it had just rained and there was water in the tub, so I doubt it's just condensation like the owner said it is.
I can't find many StarStreams though, that was the only one here just east of GTA, and there is just one more past London that I haven't seen yet.
44,066 PostsLatest Activity: Apr 15, 2026
