Ralph_Cramden
Sep 02, 2018Explorer II
A 2004 Travel Star is laminated panel construction including the floor, and dealing with the laminated construction is not anywhere close to being simple as just replacing "sheets" of plywood. It can be done, and has been done, but it's not exactly easy and involves adding a lot of additional supports, as the aluminum structural supports in the panels are placed far apart. The top layer of the floor under the vinyl flooring will be nominal 1/4" (around 3/16") and the bottom layer 1/8" with 1x1-1/2" aluminum tube on 32" or wider centers with nothing between but 1-1/2" beaded foam. On the wall panels they'll have 1/8" plywood inner and outer with 1" tubes and foam between, those tubes could be 4' apart or further with no framing whatsoever around openings.
