StarryOne
Sep 03, 2018Explorer
StarryOne wrote:Ralph Cramden wrote:
A 2004 Travel Star is laminated panel construction including the floor, and dealing with the laminated construction is not anywhere close to being simple as just replacing "sheets" of plywood. It can be done, and has been done, but it's not exactly easy and involves adding a lot of additional supports, as the aluminum structural supports in the panels are placed far apart. The top layer of the floor under the vinyl flooring will be nominal 1/4" (around 3/16") and the bottom layer 1/8" with 1x1-1/2" aluminum tube on 32" or wider centers with nothing between but 1-1/2" beaded foam. On the wall panels they'll have 1/8" plywood inner and outer with 1" tubes and foam between, those tubes could be 4' apart or further with no framing whatsoever around openings.
I realized you are saying there are 2 floors?? Could you walk me thru that? 2 sheets of different sized wood?
Thank you, Ralph! Now I completely get it.. It makes more sense than what I was envisioning!
