Buckeyeclan
Oct 28, 2018Explorer II
I replace my entire floor this past spring on a 05 palomino hybrid. Found and repairs lots of leaks found before pad during the process. On mine all of the foam and both the top and under side layers of wood were removed. basically all that was left was the aluminum tube and bottom fabric. I made a grid out of 2x material to get some structure then a layer of 1/4 exterior grade ply under all full height walls and cabinets. Then anther layer of 1/4 ply to carry the traffic. Staggered all the joints. I did not use treated material as there is a chance that it could react to the aluminum. I also used the pink solid foam in the gaps of my grid for insulation. This stuff will not wick moisture like the original stuff. I think I have some pictures and will try to post them when I get a chance
