Cocky_Camper wrote:
Here is come things that you pretty much NEED to set up camp, most other things are luxury/bonus items:
Board to level side to side
water hose
sewer hose
4X4 blocks to black under stabilizers and jack (helps to reduce movement)
4 Wheel Chocks
A Hammer (to hammer the chocks tight to the tire to reduce movement)
3ft bubble level
Optional luxury items:
Outdoor carpet/rug
sewer hose stand
pressure reducer valve
hose Y
extra hose and sprayer to clean things off
chairs for under awning
grill/outdoor stove
... and the list can go on and on
After about the first year or after several camping trips, go through the compartments and exterior and interior and remove all of the things that you packed in the trailer, but never use.
This is a pretty good starting list.
I wouldn't call the pressure reducer a luxury. With plastic tubing, you need to be sure you don't have too much pressure on your water lines. Burst one and your camping trip will be cut short.
I use the hose Y and extra hose EVERY trip out.
Get a 25' water hose that will be used about 99.9% of the time. Then get a 10'-15' extra hose that will only be used about 5% of the time, but is critical when you need it.
Same with sewer hose. Get about 20' that you will use about 99% of the time. Then, get an additional 10'-15' section that will only be used about 5% of the time, but is critical when you need it.
One of the best ways to help with trailer rocking is to extend the stabilizers as little as you can. In other words, put blocks under them as high as you can get them and the blocks still be stable. We actually have three packages (10 per package) of the plastic levelers. In addition, I carry about a dozen pieces of 4 X 4 that are about 12" long.
The further you have to extend your stabilizers, the less effective they are.
