eveready1289
Oct 20, 2014Explorer
Steaming hot water out of HWH?
I recently bought a 1997 KZ Sportsman tc from a private party.
I filled the water tank to check to see if the water heater will
work. It works but, it heats the water till its scalding hot.
I shut it off, worked the temp. setting back and forth, and tried
it the next day. I set the temp. to the low setting and fired it up again. It ran 25 min. straight and was steaming hot again. I shut
it down again. This isn't a normal temperature for the hot water
is it? I don't think the camper has been used a lot, its whole life.
Would this be a hot water system problem from it not being used for a long time, or very often?
