Me_Again
Mar 17, 2014Explorer III
ivbinconned wrote:
We were about to reinstall the "stableizer" when it occured to us to put a dial gauge on the pitman extender where the bearing rides and we found unacceptable movement of up to 40 thousand in the 120 degree swing.
That is bothersome as we conclude that if the stabilizer were installed then that stress would be forced back into the box/frame of the truck.
Did you have the tires off the ground when you did this test or the drag link disconnected? Is the run out in the box or the extender. I have had Darin's Steering Stabilizer on you 2001 for around 12 years without a problem. Chris
44,056 PostsLatest Activity: Jan 01, 2026
