Huntindog
Jun 13, 2014Explorer
It is NOT the hitch. I have used a single friction control, then a double, and am now on my second Equalizer. Never had this issue. Start with the simple stuff. Are all tires at the proper PSI? Best to check it early in the morning, as the sun can heat one side up, causing the psi measurement to be off.
It also could be a alignment issue with the TT. That could cause it to pull to one side. It could be a dragging brake or a tight bearing as well as well.
44,071 PostsLatest Activity: Aug 30, 2026
