astraelraen
Jun 13, 2014Explorer
Sounds like an easy solution is to have a shop check the axle alignment and brakes/bearings? It is a 2007 trailer so its possible none of that has ever been done.
If that checks out ok then it must be a tow vehicle/hitch issue?
I guess I am not too "worried" we towed the last travel trailer that had the same "issue" for at least 2000 miles with no ill effects. I am guessing if you had bearing issues or brake issues 2000 miles would make a problem really apparent.....
44,071 PostsLatest Activity: Aug 30, 2026
