carringb
Jun 14, 2014Explorer
dodge guy wrote:
Bryan. No, the wheel is always down slightly to the left. Around 11:30 position. And it doesn't pull, the wheel is just off! Annoying, but nothing bad. The trailer tires wear evenly as do the truck tires. I think it's just the weight on the rear axle pushing the truck to one side.
Yeah, that sounds like the nature of older steering setups, because front ride height changes the drag-link angle. My van is the same way. If I have the motorcycle rack up front, the steering wheel is pointed right about 15-degrees, even though the van still tracks straight. If I tow without weight distribution, then it hangs out slightly to the left.
I don't think this is the same problem the OP is having. Sounds like his truck has a steering force to one side or the other (and probably wants to drift that way if he took his hands off the wheel). Friction hitches by their nature are able to hold an angle between the truck and TV, but with longer/heavier rigs the combination is better able to overcome that, either by being able to overcome static friction to line them up, or because the trailer is the one dog-tracking instead.
44,071 PostsLatest Activity: Aug 30, 2026
