carringb
Jun 14, 2014Explorer
astraelraen wrote:
My problem is both left and right. Generally the wheel will be "off" in the direction you made a turn. I.e. if you made a right turn and go to straighten the wheel it will be off center to the right and vice versa.
A simple fix would be adding some grease to the contact surfaces on the bars. This will however reduce sway control, so you might have to experiment a little to find a balance. Some Vaseline might be a good start, since it won't lube as well as automotive grease, and is easy to clean off. Plus, it'll take away some of the moans and groans!
44,071 PostsLatest Activity: Aug 30, 2026
