Huntindog
Jun 15, 2014Explorer
smkettner wrote:The OP is only having the issue in one direction. If it were the hitch, it should be happening in both directions. And if it were the hitch adjustment, putting it on a different TV may make the issue go away, as the adjustment on another TV will most certainly be different.. Since it is only one side, focus on the causes that are side specific. Low tire psi, a dragging brake, a tight bearing, a alignment issue, etc.
Any chance to put the hitch on a buddy's vehicle and see if the effect is consistent between vehicles?
I speculate the hitch is binding up a bit.
Also have someone that understands the issue follow or drive so you can follow in a separate vehicle and check visually if the combo is tracking straight.
44,071 PostsLatest Activity: Aug 30, 2026
