Hybridhunter
Jun 15, 2014Explorer
BenK wrote:
To the OP...next time try this and report back on this thread what happened
After a turn or going on a curve, over correct a bit to reset the WD Setup
I think your WD setup is NOT returning to center and is off line a bit in the
direction of the last turn/curve/etc
By going a bit over center to the 'other' direction, think your WD Setup will
be more 'centered' and not impart that 'kink' in the center your setup (at the
ball)
More likely the friction sway than the WD aspect IMO. Easy enough to disable both individually.
44,071 PostsLatest Activity: Aug 30, 2026
