BurbMan
Jun 16, 2014Explorer III
BenK wrote:
To the OP...next time try this and report back on this thread what happened
After a turn or going on a curve, over correct a bit to reset the WD Setup
I think your WD setup is NOT returning to center and is off line a bit in the
direction of the last turn/curve/etc
By going a bit over center to the 'other' direction, think your WD Setup will
be more 'centered' and not impart that 'kink' in the center your setup (at the
ball)
Agree 100% here and why greasing the bars on the hitch helps overcome that friction and enables it to return to center. Although that also removes most of the "built in" sway control.
We blame P-rated tires for everything from to flood to famine but Capri Racer is correct, they have no bearing on this situation.
44,071 PostsLatest Activity: Aug 30, 2026
