BenK
Jun 16, 2014Explorer
IMHO...greasing will reduce, in part, how they work to manage sway/yaw
Most all use friction of some sort. Some friction and an over center
system (that then goes into a friction mode).
That is why they make noise...over coming the friction and the over
center point. So defeats part of their functional attributes
Even the silent Anderson system uses friction material on the ball's
tapered shank.
So they all will leave the setup off center by the amount of friction
vs the setup and whether it went past center to center, if that makes
sense to you folks
The only system I've seen to date that does NOT use friction is the
Blue Ox and will be my next WD system. They do have a kinda sorta
over center method, but it's to do with the two spring bars...not a
cammed system. The other WD cammed systems also have this inherent
in that the two spring bars push/pull back to a null position...or
try to
Oh...there is another, but I'm no longer interested in the Pullrite
system. Still think it's the best of the best, but the fact that it
stays with the vehicle when not towing and the biggie...reduced ground
clearance is something am not fond of
Pullrite's do NOT use friction, but manages by removing the lever arm
to the TV's rear axle (greatly reduced to a few inches vs a few feet).
To behave much like a Fiver's PIN location over the TV's rear axle
Guess the HA & the like into this, as they project the pivot point to
be nearer the TV's rear axle center line. I've never experienced the
'bump' folks talk about, but am not interested in the HA either
tapered shank.
sense to you folks
try to
44,071 PostsLatest Activity: Aug 30, 2026
