kvangil
Jun 18, 2014Explorer
1. lube it.
2. You can add up to 8 spacers. However, I think based on your numbers, you should be ok with the weight that's already being distributed.
3. You're right...that angle looks a bit off. Mine are basically parallel with the a-frame. You may want to lower the L-brackets a notch.
4. Not sure what your loaded tongue weight is, but the 1000 lbs bars may be a bit on the light side with a fully loaded tongue and truck bed, considering you're close to GVWR. I think the 1200 bars should be ok.
44,071 PostsLatest Activity: Aug 30, 2026
