astraelraen
Jun 18, 2014Explorer
kvangil wrote:
1.
3. You're right...that angle looks a bit off. Mine are basically parallel with the a-frame. You may want to lower the L-brackets a notch.
It takes that much of an angle to get front weight distribution to where it is. If I lower the bars it will take weight off the front per Equalizer manual? The manual says to put more spacers in OR raise the bars up to increase the amount of weight distributed to the front.
So maybe I could go up to 8 spacers and maybe back off some on the bar height...
44,071 PostsLatest Activity: Aug 30, 2026
