Hybridhunter
Jun 19, 2014Explorer
MitchF150 wrote:
The trailer is pretty low (only has 2 steps). The tongue is about 18" to the top when hitched up.
What I'm talking about a "2 inch rise ball" is this.
You would replace this with your current ball.
Since it's taller, you will have to lower your hitch head. Since your stinger is 'inverted', you'll have to turn it over and adjust the head accordingly to match up to the new balls extra height, but keep the trailer at the same level.
This will give you the additional space between your bars and the frame.
Mitch
Don't use a riser ball unless it is rated for use on a WDH. The torsional stress will likely destroy it.
44,071 PostsLatest Activity: Aug 30, 2026
