goducks10
Jun 20, 2014Explorer
You need a longer shank unless you can move the WDH higher. Your ball should be the same as the coupler according to the EQ instructions. Get a good measurement on the coupler then figure what you need for the ball. If your coupler is 29" then the ball should be at 29".
FWIW I was thinking about this last night. I wonder if some of the steering wheel alignment problem is coming from the fact that the bars are tilted so high that its causing too much friction at the socket connection.
44,071 PostsLatest Activity: Aug 30, 2026
