astraelraen
Jun 27, 2014Explorer
ah64id wrote:
Here is how my setup looks. I have the L brackets up 1 from level because when fully loaded I am near capacity of these 1200lb bars, and should sell this hitch for a 14K setup.
The 1" riser ball, which only adds 5/8" or so was more for leveling than tension but it did both. I could consider removing it now with the TT siting 3/8" or so lower with the EZ-Flex, but I haven't.
The bracket jackets, hard to see in this photo, do help when the bars are slightly off parallel because plastic wears and makes a level contact surface.
I had the hitch adjusted and moved the ball up one inch. I also had another spacer put in so it is up to seven spacers. I adjusted the L brackets and now my setup looks much closer to yours. Unfortunately because of our move I have not had the opportunity to get all the family in and load it up to see how it drives and/or weigh it.
44,070 PostsLatest Activity: Sep 18, 2026
