astraelraen
Jun 27, 2014Explorer
Gdetrailer wrote:
Does the truck have a "lift" kit and or oversized tires installed?
If so your front end may need alignment.
Since the truck is having this issue with only a few hundred pounds in the bed it really points to something WITH THE TRUCK being wrong and completely rules out trailer and WD.
My suggestion is to put 400 lbs or better (what ever amount of weight it takes to get it to steer off angle) in the bed and take to your dealer and have them go for a test drive. In order to get anything under warranty they (Ford dealer) must see the problem happen.
No the truck and tires are stock / OEM. I will find some time to do that.
44,070 PostsLatest Activity: Sep 18, 2026
