sac89
Aug 31, 2017Explorer
Sticking Lever
Good Morning, Last time we went out, after hooking up to the sewer line at the campground, my black tank lever was super hard to open. Not sure why or what preventative maintenance can be done to en...
sac89 wrote:You sit on site with the black valve open? I think you're causing your own problem. Leave the valve closed. Only open it to dump when the tank is filled at least half way, then close it again. Otherwise stuff doesn't get flushed through all the way through. That includes stuff building up in the area where the gate valve closes.
(although difficult to close when the weekend was over)
