Gdetrailer
Aug 28, 2022Explorer III
plasticmaster wrote:
My blue ox hitch does not tilt. The battery tray is welded to the A frame and sits lower than the a frame. It's a Forest River Vibe.
Post a couple of pictures with it hooked up..
Model number may also be very helpful.
Bars should not be able to swing much when turning but I could see there may be enough slack from the chains to allow the bars to swing into an obstruction like a battery tray that sits to far below the A frame..
Stronger bars may result in way overcorrecting the WD which is why I mentioned checking and verifying the amount of restoration to the front axle. This needed done anyways since you changed TVs, the amount of restoration can vary between vehicles and you may find the newer vehicle may not need as much as the old one did.
