I'll just add to make sure you look UNDER the handles where it clips on to the bottom on whatever plastic tubs you decide to buy!
I did not.:(
I had 2 storage tubs that where in the aisle when traveling and placed outside when parked for more than the night.
All went well traveling up North THEN I came South. And found bugs inside the tubs. That then got into my RV.
What I found is On some plastic tubs there are holes drilled into the tub under the handle on the bottom part of the tub. :S
The southern bugs just walked right inside my tubs thru the holes in under the handles.
