Dr_Quick
Mar 22, 2015Explorer II
I have changed to a larger storage door and added doors. The main thing that you will need to do is provide framing around the perimeter of the new door as you will have to secure the frame to something solid. If you can locate some of the studs, you can possibly use them as part of the structure to secure to. Adding framing is tricky, if you my have to cut out a stud that is in the way. Which means that you will have to trim it back inside the wall so that a new cross piece of framing can be added.
44,066 PostsLatest Activity: May 13, 2026
