Freeborn530's avatar
Freeborn530
Storing generators when traveling?
Recently acquired two Yamaha portable generators. I have a crew cab truck and usually keep propane grill, chairs in the back ... Should I keep the generators in the camper when on the road, for example stopping for shopping? Or in the back seat area covered by tarp?
  • I don't see how carrying something with a gas tank out in front of the bumper solves all safety issues . Prior to 1973 all 3truck makers had the gas tank in the cab behind the seats . Not the best but not the worst either . As mentioned earlier , where ever it is it needs to be secured .
  • If you put a MicroAir on your AC, you should only need one 2,000 cc generator. When you carry a generator in the cab, run a ratchet type strap through the handle and hook the strap to the seat mounting hardware to prevent the generator from becoming a projectile.
    Some folks do carry their generators inside the cab of the truck while driving. Me, I'd never do it. A very bad collision or rollover could easily turn those generators into projectiles---not to mention the general risk imposed by the generator's fuel tank being located inside the passenger compartment---especially during a serious accident. Like Kayteg1, I'd vote for the front of the truck (best weight distribution) or the outside rear. Maybe the inside of the camper as a last resort.
  • Obviously when you have truck prone to overheating - that might not be good option.
    With my set I drove to Death Valley couple weeks ago, where I recorded 124F.
    The return trip is quite a mountain climbing so engine got hotter than usual.
    Ford pops digital display when engine gets hot, so mine never went above 220F, when I was pushing 60mph on steep grade.
    The radiator fan never come on.
  • Hi Keytag1,
    That doesn't always work. I tried a front mount and the engine ran about 20 F hotter, getting up to 227 F.
    I did like how the ride improved.
  • Both ideas will have gasoline fumes issues.
    I carry my Honda 3000 of front hitch and not only that solves all safety issues, but also helps in keeping COG more forward.
