valhalla360
Sep 12, 2022Navigator
fj12ryder wrote:Grit dog wrote:Okay, I'm a little confused. Where does the air come from that displaces the fuel as it's pumped out and used? Or does it create a vacuum? If the air isn't run through a drier, then it will have some water vapor in it, which can condense out and precipitate into the fuel.
Run DEF low unless you’re deleted. Run fuel low. Change the oil if you’re OCD and either disconnect or put a battery maintainer on it.
The full fuel tank thing is from times past when tanks had open vent systems and tanks were steel. And even at that, large amounts of condensation are really only a risk if exposed to the elements.
There will be a pile of people that say this is wrong, but I haven’t filled a tank in anything stored off season for 30 years. Carbed, efi, 2 smoke, 4 stroke or diesel.
Even old iron. I just spent 2 years restoring a truck. It did get started occasionally but sat for up to 6 months. Unheated shop, no problem. Only thing I did was put AV gas in the tanks so the fuel didn’t varnish.
All that said, only 6 months, you could turn it off, disconnect the batteries and shut the door and it would still be fine.
Modern fuel systems are complicated beasts using valves, solenoids, carbon canisters, etc... They are designed to only allow air in at appropriate times and will actively control it. They are sealed so fuel vapor can't escape into the air when just sitting there.
But even with old fuel systems, it really wasn't an issue. Yes, air can have some water vapor in it but if you run the numbers, if you change out the air daily and extract every molecule you might get a few grams of water in the fuel over 6 months. Easily handled by the trucks separator.
I'm convinced the vast majority of water in fuel comes from the gas station (and it's far less common today) or from leaks leading into the fuel system (more an issue with something like a boat where it's common for the fuel fill to be on a horizontal surface where water can pool around a poorly sealed fill.
