PA12DRVR
Oct 06, 2022Explorer
Just put one of my diesel p/u's to bed for the winter...of course, Los Anchorage then got a record high. :(.
In any case:...pulled two batteries out and into the garage where they'll get charged once a month or so on the trickle charger. Filled the fuel tank with winter blend and added a bit of Stabil. I think DEF was at about 1/3....didn't do a thing with it.
If the OP is storing in Western WA, probably won't see real cold weather. However, if you anticipate -10 or colder, I'd recommend going the trickle charger route and not "just" disconnecting leads. I've had fully charged batteries work fine to -30 or so (beyond that is the general range of colder than heck...and I don't do much in those temps anymore). A depleted charge battery will freeze in those same temps...as I've found out twice with the house batteries at the cabin.
