JIMNLIN
Oct 24, 2014Explorer III
Years ago before I built a trailer shed my RV trailer sat in the shade on the north side of my tractor barn....but it was always parked 24/7 on 1"x12"x12" plywood or 2" x 8"s to eliminate moisture.
This from Goodyear Tire website;
How Not to Store Your Tires
Don't store tires in an area that is wet, oily or greasy
Don't store tires where they are subjected to direct sunlight or extreme temperatures
Don't store tires near electric motors or other ozone-generating sources
Don't store tires on black asphalt or other heat-absorbent surfaces
Don't store tires on or adjacent to highly reflective surfaces such as sand or snow
Storing Your Vehicle Without Removing the Tires Ideally, a vehicle in storage should be placed on blocks to remove all weight from the tires. If the vehicle cannot be put on blocks, follow these steps for tire protection:
Completely unload the vehicle so that minimum weight will be placed on the tires
Inflate tires to recommended operating pressure plus 25%. Ensure that the rim manufacturer’s inflation capacity is not exceeded
Be sure the storage surface is firm, clean, well drained and reasonably level
Avoid moving the vehicle during extremely cold weather
Move the vehicle at least every three months to prevent ozone cracking in the tire bulge area, as well as “flat-spotting” from the prolonged strain of sidewall and tread deflection
Adjust inflation before putting the vehicle back into service
