crazyro's avatar
crazyro
Storing trailer - slide in or out?
I apologize if this has been discussed before, but I couldn't find any info.
When storing the TT for long-ish periods of time (two weeks or more, let's say), do you do so with the slide out or in? I've always stored mine with it in, but have seen several with slides out.
Thoughts? Much appreciated.
E.
  • In/out makes no real difference. At home I leave them open during the summer. Easier to do things that way. Right now there closed because I have planted new grass out there.
  • I don't have slides. If I did, they would be in during storage.
    It would be less area for the wind to catch or throw something against the TT and less chance of a leak. JMO
  • With most slides, they seal as well in as out but I like Bill's reasoning for keeping it in.
    Also, if your like me and you heat it just enough to keep it from freezing, you have less area to heat with it in.
    I don't think either way is wrong.
  • In if it's in storage and not in use. What if you went to pull it out of storage and the slide wouldn't go in for some reason?
    Bill
  • When ours is not in use, we keep the slide closed. No purpose served in keeping it open. Would just have to close it to head on down the road.
