And next ladies and gents, I noticed some unusual wear on my front tires, and got to checking things in the front end. I had some loose ball joints and worn tie rod ends. So, I just bit the bullet and replaced everything.
New ball joints (upper and lower), new tie rod ends (inner and outer), and since I was in there, new complete strut assemblies which were the original ones and seemed ok but... then of course a wheel alignment is needed. The bill was $1000 all in, but I got the parts cheap and had a friend with a lift do the work. This truck has to last me 3 more years at which time I will retire from law enforcement and move. So hopefully this is the last major fix. The truck is a high miler that had 240,000 Km (150,000 miles) when I got it and now has 254,000 Km (160,000 miles) on it. I have no idea what kind of life it lived before I bought it. When I forst got it, I changed all the fluids and the engine and trans seem solid, the pan was relatively clean when I dropped it to service the transmission. The rear end howls a bit on coast down, but at least it now has new fluid, and the magnet wasn't too loaded up when I took the diff cover off to service the rear end.
When doing my last oil change, I did notice I have at least one broken exhaust manifold bolt, but there may be others. It does have a bit of a tick sometimes. Not sure if that is "Hemi Tick" of the broken manifold bolt. I think I'll save that job for next year.
