spike99
Aug 14, 2013Explorer
Who installed the Brake Controller within your 2012 Nissan Quest minivan? Did they install it properly?
I have a 2009 minivan and its brake controller instructions stated to connect to the vehicle's brake pedal wiring. Very nice diagram as well. Before installing, I did lots of surfing and discovered this is "incorrect" (and dangerous - if connected this default method). For my brand of minivan, I do NOT connect the brake controller to its brake pedal wiring. Instead, I must connect the brake controller to a white wire - coming out of the vehicle's computer box - located under the dash. This white wire (BCM unit #2 - position 3 / white wire) is the brake signal wire. As per my vehicle dealer service dept, this white wire is correct - for my specific vehicle. If wondering, BCM is Body Control Module (which is a mini-computer box). Every vehicle has minimum 1 box. Mine has 2 boxes.
With above in mind, do "double check" with your vehicle Dealer's Service Dept. And, confirm with Google Search as well.
Hope this helps.
Hope this helps.
44,071 PostsLatest Activity: Sep 17, 2026
