Durb
Jun 25, 2023Explorer
You probably have automatic vents for the gray tank under your kitchen counter and under the vanity in the bathroom. If these go bad, and they do, your gray tank will gladly share all its smells with the trailer. I hope your drain valve is not open and you are not hooked up to the park's sewer. If so, and with bad auto vents, you will get to enjoy the sewage smells of all your neighbors. Some people insist on doing this, can't figure out why.
Try filling your traps slowly in the kitchen and bathroom, then wrap plastic wrap over the auto vents with a rubber band. See if the smell goes away. Could be, the auto vents don't open and are causing your traps to siphon dry.
I would also consider previous mice and rats as being an issue. They don't see well, so they pee everywhere to help them navigate by smell. Stick your head in a storage compartment to see if it is worse. Also, remove an electrical outlet to access the inside of a wall, and give the hole a good whiff. No help here as how to remedy.
I hope your problem is from the auto vents; they are cheap and easy to replace. Who knows, maybe the previous owner liked to eat asparagus and urinate in the shower which goes right to the gray tank.
