aftermath
Aug 01, 2023Explorer III
Yes, thanks for the followup. But then....you said you had the same issue on your last trip? OK, here is my two cents worth. There have been many good suggestions but you should zero in on these. 1. You can't have a blockage in your venting system. 2. You are wise to dump your tank completely and then recharge it with a chemical of your choice and 3. and I think this is your main issue, you need to use plenty of water. Read the directions on the chemical packet and they suggest you add the chemical to your tank after you have added something like a gallon of water. Water after that will be your friend. Think of using little to no water and think of how difficult it will be to actually empty the black tank.
As far as what kind of toilet you have, don't get all taken up with that. I had a Dometic something and changed to a Dometic 310 but only because the 310 was porcelain. Neither one is any better than the other when it comes to basic functionality. Water, water and water is the key.
